[GRASS-dev] new std options for files
Glynn Clements
glynn at gclements.plus.com
Fri Sep 7 16:57:17 EDT 2007
Markus Neteler wrote:
> >> Hamish wrote:
> >> > as earlier mentioned* I'd like to change the Option struct to
> >> > rationalize the ->description and ->label parts.
> >> > currently, if a label is defined it becomes the description, and the
> >> > description becomes the tooltip. This is non-intuitive and
> >> > inconsistent.
> > so we have three possible levels of verbosity for an option description:
> > ->label: a few words
> > ->description: a sentence
> > ->tooltip: a paragraph/short example showing format (doesn't exist)
> > I think it is a good idea to keep ->description (as commonly used now)
> > short and to the point, ie shorter than ~65 chars (so it fits on one
> > line). Certainly the label should quite short. It looks bad when the
> > description is line wrapped in --help, or colliding with the right side
> > of the GUI window.
> I would like to bring up this issue again (since I am confused):
> Currently only about 10 modules use
> module->label
> In the GUI pop up it is even printed in the wrong vertical order
> if above definition is true + there is ugly vertical space between
> these two lines.
> Question: what's the point of module->label?
For use as a label in the GUI in case the description is too verbose.
> Take it out or
> modify 290+ modules? We need some consistency...
Leave it as-is.
> Is there anything using module->label|description as tooltip?
Any option which has a separate label will have the description as the
tooltip.
> confused (about why we need two things to do nearly the same),
Some descriptions are too verbose to use as labels in the GUI.
