[GRASS-dev] Re: export 3d vector line map to shp
Martin Landa
landa.martin at gmail.com
Tue Sep 11 14:02:39 EDT 2007
OK,
this ugly patch enables to export 3d shapefile using v.out.ogr
lco="SHPT=ARCZ" ...
Martin
2007/9/11, Martin Landa <landa.martin at gmail.com>:
> Hi,
> I got problem exporting 3d GRASS vector map to Shapefile. I have a
> vector map with 3d lines (contours).
> $ .out.ascii isolines_reggio format=standard | head -n 20
> ORGANIZATION:
> DIGIT DATE:
> DIGIT NAME: martin
> MAP NAME: Output from v.overlay
> MAP DATE: Tue Sep 11 00:50:19 2007
> MAP SCALE: 1
> OTHER INFO:
> ZONE: 0
> MAP THRESH: 0.000000
> VERTI:
> L 20 1
> 618866 949571.5625 100
> 618824.8125 949549.6875 100
> 618815.8125 949537.1875 100
> 618820.8125 949524.6875 100
> 618810.8125 949486.3125 100
> 618774.5625 949423.6875 100
> 618767.0625 949372.8125 100
> 618746.375 949349.8125 100
> 618728.8125 949360.3125 100
> I tried to export the map using
> $ v.out.ogr in=isolines_reggio dsn=./ olay=isolines_reggio
> For testing...
> $ v.in.ogr dsn=isolines_reggio.shp out=test -z
> v.out.ascii test format=standard | head -n 20
> ORGANIZATION:
> DIGIT DATE:
> DIGIT NAME: martin
> MAP NAME:
> MAP DATE: Tue Sep 11 19:46:07 2007
> MAP SCALE: 1
> OTHER INFO:
> ZONE: 0
> VERTI:
> L 20 1
> 618866 949571.5625 0
> 618824.8125 949549.6875 0
> 618815.8125 949537.1875 0
> 618820.8125 949524.6875 0
> 618810.8125 949486.3125 0
> 618774.5625 949423.6875 0
> 618767.0625 949372.8125 0
> 618746.375 949349.8125 0
> 618728.8125 949360.3125 0
> The Z coordinate is lost...
> According
> http://gdal.org/ogr/drv_shapefile.html
> I tried
> v.out.ogr in=isolines_reggio dsn=./ olay=isolines_reggio lco=SHPT=ARCZ
> ERROR 6: Unknown SHPT value of `ARCZ=YES' passed to Shapefile layer
> creation. Creation aborted.
> ERROR: Cannot create layer
> Thanks for any tip...
> Martin
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
