[GRASS-dev] [grass-code I][483] tcl/tk GUI windows exit with status 1 instead of 0
grass-dev at grass.itc.it grass-dev at grass.itc.it
Fri Sep 14 06:10:32 EDT 2007
code I item #483, was opened at 2007-09-14 12:10
Status: Open
Priority: 5
Submitted By: Maciej Sieczka (msieczka)
Assigned to: Nobody (None)
Summary: tcl/tk GUI windows exit with status 1 instead of 0
Issue type: library bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: tcl/tk GUI
Operating system: None
Operating system version: Ubuntu Dapper GNU/Linux
GRASS CVS checkout date, if applies (YYMMDD): 070914
Initial Comment:
tcl/tk GUI windows exit with status 1 even if no error took place.
To reproduce:
1. v.info [Enter] (or any other command)
2. press "Close"
3. echo $?
The result is "1" like if there was an error. There wasn't, so it should be "0".
I can reproduce this in 6.2 CVS and older 6.3 instalations (dating back to April 2007), so it seems not a newly introduced bug.
Maciek
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=483&group_id=21
