[GRASS-dev] frequent segfaults of tcl/tk windows on a 64bit box
Maciej Sieczka tutey at o2.pl
Sun Sep 16 08:49:02 EDT 2007
Hi
Does anyone experience frequent segfaults of the autogenerated tcl/tk
windows on 64bit GNU/Linux machines like me?
On several 32bit machines it never happens, but on the 64bit one it
happens very often, both in GRASS 6.3 and 6.2, built and running
against tcl/tk 8.4.12 on Ubuntu Dapper. It's been so for few months
now. No matter what command. The crash has random nature. Sometimes the
same command works few times in a row, sometimes it crashes right after
I press the "Run" button.
For example, the following command run from tcl/tk GUI inside gdb:
v.overlay ainput="lulc_obszar_mestichblatt at lulc_dhdn" atype="area"
alayer=1 binput="lulc_obszar_utm25k at lulc_utm25k" btype="area" blayer=1
output="union" operator="and" olayer=1,0,0
crashed like this:
$ gdb v.overlay
(gdb) run
Starting program: /usr/local/grass-6.3.cvs/bin/v.overlay
[Thread debugging using libthread_db enabled]
[New Thread 46912562427840 (LWP 18035)]
warning: Lowest section in /usr/lib/libicudata.so.34 is .hash at
00000000000000e8
Program exited with code 01.
(gdb) bt
No stack.
Core was dumped, so I run:
$ gdb -c core.16726
This GDB was configured as "x86_64-linux-gnu".
Using host libthread_db library "/lib/libthread_db.so.1".
Core was generated by `wish'.
Program terminated with signal 11, Segmentation fault.
#0  0x00002aaaaac11768 in ?? ()
(gdb) bt
(gdb)
Not much information here I guess. The output vector is broken:
$ v.info union
ERROR: Cannot open existing vector <union at oir> on level [2]
$ v.build union
WARNING: coor files of vector 'union at oir' is larger than it should be
         (36730 bytes excess).
Building topology ...
0 primitives registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes     :   0
Number of primitives:   0
Number of points    :   0
Number of lines     :   0
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
So it's empty. There should be one area instead. Moreover, the v.build
run takes surprisingly long I guess - about 5 seconds, on an Intel Core
Duo E6600 2,4 GHz running 2.6.15-29-amd64-xeon.
Does anybody know how to solve the problem? Is it a matter of tlc/tk or
GRASS?
Maciek
