[GRASS-dev] g.mlist problem
William Kyngesburye
woklist at kyngchaos.com
Tue Sep 18 09:47:11 EDT 2007
Same happens for me (OSX). I walked thru the script commands
manually, and it is indeed messing up on the first sed.
I see this in the sed man for Sed Regex info (OSX uses the BSD sed):
2. The escape sequence \n matches a newline character embedded in the
pattern space. You can't, however, use a literal newline
character
in an address or in the substitute command.
Later, for the s/ function, it says:
A line can be split by substituting a newline character into it.
To specify a newline character in the replacement string, precede
it with a backslash.
Putting a real newline after the \ does the trick:
g.list type=$type mapset=$mapset \
| grep -v '^-\+$' \
| grep -v "files available" \
| grep -vi "mapset" \
| sed 's/ */\
/g' \
| grep -v '^$' \
| grep "$search" \
| sort \
| sed -e "s/$/$MAPSET/"
On Sep 18, 2007, at 2:15 AM, Michael Barton wrote:
> Wolf,
> I just checked the 'binary' version against the source version of
> g.mlist.
> Both are identical.
> There must be something problematic in the new code. Has anyone
> else had
> this problem?
> Has this been tried on a Mac? I don't know what difference that
> would make,
> but maybe something... I do know there there are some differences
> in Mac OS
> X awk and Linux awk. I don't know about sed and bash.
> Michael
> On 9/18/07 12:01 AM, "Wolf Bergenheim" <wolf+grass at bergenheim.net>
> wrote:
>> On 18.09.2007 09:56, Michael Barton wrote:
>>> I tried the new fast g.mlist and got very weird results. Running
>>> g.mlist
>>> rast returned mapnames like...
>>> elevation.10mnrstrct.areasn
>>> ... instead of
>>> elevation.10m
>> It seems there is a missing \ before the n somewhere in the code,
>> since
>> \ + n => \n = new line. Or then your compiler doesn't handle "\n"
>> properly.
>> --Wolf
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
