[GRASS-dev] Re: proposal for grass extensions and addons
William Kyngesburye
woklist at kyngchaos.com
Wed Sep 19 22:55:57 EDT 2007
On Sep 19, 2007, at 9:36 PM, Michael Barton wrote:
>> We should also aim for one unified mechanism and extension format,
>> as we will not be able to keep more than one supported in the long
>> term.
> Also agree sort of. There are different ways of *making* extensions,
> scripts, the GEM approach, William's makefile approach, and certainly
> others. It's probably a good idea to settle on a limited number of
> these
> (e.g., decide on the best way to compile a binary from source, and
> a best
> way to distribute a binary, etc.).
> But at the moment, I think it would be good to first focus on what
> we do
> with extensions however we make them. For this, we need some kind of
> standard that makes them easy to use from the command line and easy
> to run
> as menu items in the GUI.
> If we get this far, we can use the experience to go the next steps.
Glynn mentioned in the v.in.dwg discussion that the makefile
fragments present in a 6.3 install are meant to enable building
modules from source without the full GRASS source. I had noticed
these some time ago. I need to try it out - it's basically what I'm
doing with my external build makefiles.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what
does that remind me of? Ah, yes - life."
- Marvin
