[GRASS-dev] [grass-code P][488] Makefile fix for i.atcorr
grass-dev at grass.itc.it
Fri Sep 21 04:39:59 EDT 2007
code P item #488, was opened at 2007-09-21 17:39
Status: Open
Priority: 3
Submitted By: Etsushi Kato (ekato)
Assigned to: Nobody (None)
Summary: Makefile fix for i.atcorr
Patch status: None
Patch type: fix
GRASS component: imagery
GRASS version: CVS HEAD
GRASS CVS checkout date, if applies (YYMMDD): 070915
Initial Comment:
I got a compile error with i.atcorr since <libintl.h> included from <grass/glocale.h> is installed at /sw/include on Mac OS X using Fink. I think Makefile for i.atcorr should have $(COMPILE_FLAGS_CXX).
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=205&aid=488&group_id=21
