[GRASS-dev] native WinGRASS and attribute data deadlock, next try
Moritz Lennert
mlennert at club.worldonline.be
Sun Sep 23 15:04:08 EDT 2007
On Sat, September 22, 2007 05:27, Glynn Clements wrote:
> My next suggestion is to re-write xdr_stdio to use read() and write()
> instead of fread() and fwrite(), e.g.:
> - if (fread((caddr_t)lp, sizeof(long), 1, (FILE *)xdrs->x_private) != 1)
> + if (read(fileno((FILE *)xdrs->x_private), (caddr_t)lp, sizeof(long)) !=
> sizeof(long))
That seems to work !
I just changed the four occurrences of fread/fwrite to read/write (see
diff attached) and now v.out.ogr runs smoothly both with Benjamin's test
point data and with the spearfish landcover areas.
I'll post new binaries as soon as compilation is over, so that others can
test as well.
Thanks a lot, Glynn !
Moritz
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070923/f87704c5/xdr_stdio.obj
