[GRASS-dev] Exit code for Tk GUI
Maris Nartiss
maris.gis at gmail.com
Mon Sep 24 09:36:08 EDT 2007
2007/9/24, Glynn Clements <glynn at gclements.plus.com>:
> G_gui() can call exit() with the value returned from pclose(); it
> doesn't have to return to the caller. See my patch.
Sorry. I really misread Your patch.
Just for record if somebody is going to use it - correct way is like this:
--- lib/gis/parser.c 8 Sep 2007 16:22:21 -0000 1.130
+++ lib/gis/parser.c 24 Sep 2007 13:20:36 -0000
@@ -81,6 +81,8 @@
#include <ctype.h>
#include <unistd.h>
#include <stdarg.h>
+#include <sys/types.h>
+#include <sys/wait.h>
#include <grass/gis.h>
#include <grass/glocale.h>
#include <grass/spawn.h>
@@ -1887,6 +1889,7 @@
static void G_gui_tcltk (void)
FILE *fp;
+ int status;
if (!pgm_name)
pgm_name = G_program_name ();
@@ -1912,7 +1915,10 @@
generate_tcl(fp);
- pclose(fp);
+ status = pclose(fp);
+ if (status < 0)
+ G_fatal_error("error while executing 'wish'");
+ exit(WEXITSTATUS(status));
/* Build wxPython gui */
> If you're running the command manually from the command line, you
> probably aren't paying any attention to exit codes. If you're running
> it from a script, you're likely to be providing arguments.
Probably reporter has some use case where GUI's returned exit code has
some use otherwise there would be no bugreport about this.
TCL's close{} provides error code from launched module in "proc
Gronsole::readeof" IF in "proc Gronsole::execbg " pipeline is not
changed to be non-blocking (remove "fconfigure $fh -blocking 0").
wbr,
Maris.
