[GRASS-dev] [grass-code I][492] ps.map doesn't remove .tmp files when it is done
grass-dev at grass.itc.it grass-dev at grass.itc.it
Wed Sep 26 02:03:08 EDT 2007
code I item #492, was opened at 2007-09-26 18:03
Status: Open
Priority: 2
Submitted By: Hamish Bowman (hamish)
Assigned to: Nobody (None)
Summary: ps.map doesn't remove .tmp files when it is done
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: postscript
Operating system: Linux
Operating system version: deb etch
GRASS CVS checkout date, if applies (YYMMDD): 070926
Initial Comment:
ps.map creates some .tmp files, e.g. when the 'text' or 'rectangle' instructions are used but they aren't removed when the module finishes. For scripted ps.map jobs / trial+error iterations you end up with hundreds of tiny files in the .tmp dir until you exit the GRASS session.
They are human readable and useful for debugging, so it would be nice to only remove them if the g.gisenv DEBUG level was below some threshold.
Hamish
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=492&group_id=21
