[GRASS-dev] g.copy segfaulting in 6.3 snapshot 20070922
Maris Nartiss
maris.gis at gmail.com
Thu Sep 27 12:04:42 EDT 2007
It may be not a GRASS issue, but it would be nice to know why it
happens, as, probably, there are some tricks to disable THIS
optimization in GRASS. Like adding some *magic* in code or tests in
autoconf part to disable optimization if system is FOO.
Just 0.002$,
Maris.
2007/9/27, Volker Wichmann <wichmann at laserdata.at>:
> We did a lot of tests back then, and it seems to be a problem with the
> compiler optimisation code. This issue isn't fixed, but you can work
> around it by re-compiling g.copy without optimisation enabled (see
> thread below). I don't think it is a GRASS issue.
> Volker
