[GRASS-dev] [grass-code I][495] gis.m output window buttons don't fit text width
grass-dev at grass.itc.it grass-dev at grass.itc.it
Sun Sep 30 09:13:08 EDT 2007
code I item #495, was opened at 2007-09-30 15:13
Status: Open
Priority: 3
Submitted By: Carlos Dávila (carluti)
Assigned to: Nobody (None)
Summary: gis.m output window buttons don't fit text width
Issue type: module bad feature
Issue status: None
GRASS version: CVS HEAD
GRASS component: gis.m
Operating system: Linux
Operating system version: debian testing
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
Translated text within some buttons is larger than default width and text is cut, even if you enlarge the window.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=495&group_id=21
