[GRASS-dev] Re: [GRASS GIS] #110: db/drivers/dbf fail to build due
to undefined reference to 'SASetupDefaultHooks'
trac at osgeo.org
Tue Apr 1 08:09:29 EDT 2008
#110: db/drivers/dbf fail to build due to undefined reference to
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: dbf
Changes (by marisn):
* keywords: => dbf
Comment:
On 32bit Gentoo box with gdal-1.5.0 GRASS trunk rev. 30831 compiles just
fine, but any module, that uses dbf, fails with error:
dbmi: Protocol error
WARNING:Cannot open select cursor
(gdb) run -a map=geology at PERMANENT east_north=592948.879668,4927119.3361
distance=296.261682243
Starting program: /home/ddd/soft/grass_trunk/dist.i686-pc-linux-
gnu/bin/v.what -a map=geology at PERMANENT
east_north=592948.879668,4927119.3361 distance=296.261682243
[Thread debugging using libthread_db enabled]
[New Thread 0xb751e6d0 (LWP 17661)]
East: 592948.879668
North: 4927119.3361
Map: geology
Mapset: PERMANENT
Objekta tips: Laukums
Kavadrātmetri: 10056250.000
Hektāri: 1005.625
Akri: 2484.893
Kvadrātjūdzes: 3.8826
Līmenis: 1
Kategorija: 6
Driver: dbf
Database: /home/ddd/hdo/maris/gis_dati/spearfish60/PERMANENT/dbf/
Table: geology
Key column: cat
BRĪDINĀJUMS:Cannot open select cursor
Program received signal SIGPIPE, Broken pipe.
[Switching to Thread 0xb751e6d0 (LWP 17661)]
0xb7fb0410 in __kernel_vsyscall ()
(gdb) bt
#0 0xb7fb0410 in __kernel_vsyscall ()
#1 0xb79b7453 in write () from /lib/libc.so.6
#2 0xb79651d7 in _IO_file_write () from /lib/libc.so.6
#3 0xb7964e85 in ?? () from /lib/libc.so.6
#4 0xb7965136 in _IO_file_xsputn () from /lib/libc.so.6
#5 0xb795b19f in fwrite () from /lib/libc.so.6
#6 0xb7f77f4b in db__send (buf=0xbfe42d70, size=4) at xdr.c:80
#7 0xb7f78c55 in db__send_int (n=101) at xdrint.c:9
#8 0xb7f78d22 in db__start_procedure_call (procnum=101) at
xdrprocedure.c:11
#9 0xb7edc3b9 in db_close_database (driver=0x80e5730) at c_closedb.c:17
#10 0xb7a5d948 in F_generate (drvname=0x80e3e18 "dbf",
dbname=0x809ec88
"/home/ddd/hdo/maris/gis_dati/spearfish60/PERMANENT/dbf/",
tblname=0x80e3df8 "geology",
key=0x80e3e08 "cat", keyval=6, frmname=0x0, frmmapset=0x0,
edit_mode=1, format=2, form=0xbfe447dc)
at generate.c:88
#11 0x0804a864 in what (east=592948.87966800004, north=4927119.3361,
maxdist=296.261682243, width=7, mwidth=9,
topo=0, showextra=1) at what.c:276
#12 0x08049ae4 in main (argc=5, argv=0xbfe42db0) at main.c:175
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:1>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
