[GRASS-dev] G_exp_colors()?
Tue Apr 1 08:23:25 EDT 2008
Hamish wrote:
> I am working with MODIS Aqua imagery in HDF4 format. (level 3)
>   http://oceancolor.gsfc.nasa.gov/PRODUCTS/
> The Chlorophyll-a concentration data comes in log form, 0-65535.
> Plotting the data with a bcyr color rules makes it look great.
> I added a mini-tutorial here:
>   http://grass.gdf-hannover.de/wiki/MODIS
> The metadata (available through gdalinfo) gives the formula and test
> points to convert to mg/m^3:
>   r.mapcalc "${map}.chlor_a = 10^(($Slope * $map) + $Intercept)"
> ie a histogram of that starts high and exponentially drops to 0. By 2.0
> there are few data cells left, but real data continues up to the max in
> areas having plankton blooms.
> So how to make nice color rules for that? 'r.colors -g' does the opposite
> of what I want,
Odd. Theoretically, it should do exactly what you want.
> 'r.colors -e' shows some more detail but isn't really
> right. A custom one using 'r.univar precentile=,,,,' cues shows some more
> but isn't smooth and is a pain.
> Any ideas? Could G_log_colors() be turned on its head to make a
> G_exp_colors() function and associated 'r.colors -x' flag? Would it work?
It could be done easily enough, although I'm not sure how useful it
would be.
