[GRASS-dev] Shapelib and dbf not compiling for Mac
Michael Barton
michael.barton at asu.edu
Thu Apr 3 11:14:43 EDT 2008
I guess I¹ll try again to see if someone has some advice on this. The
current SVN trunk won¹t compile on Mac OSX 10.4 (or at least it won¹t
compile for me with OSX 10.4).
I updated again last night, did make distclean, configure, and compile.
Configure ran fine. My configure string follows the error output below.
I have errors in ./lib/external/shapelib and in ./db/drivers/dbf.
Wiliam Kyngesburey thinks they may be related but isn¹t sure what is causing
them. The full error output is below. Any suggestions are helpful.
Thanks.
Michael
Following modules are missing the 'description.html' file in src code:
d.paint.labels
p.out.vrml
r.cats
GRASS GIS compilation log
Started compilation: Wed Apr 2 19:44:52 MST 2008
Errors in:
/Users/cmbarton/grass_dev/grass_src/lib/external/shapelib
/Users/cmbarton/grass_dev/grass_src/db/drivers/dbf
/Users/cmbarton/grass_dev/grass_src/gui/wxpython/vdigit
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Wed Apr 2 19:57:28 MST 2008
make: *** [default] Error 1
cmb-MBP-2:~/grass_dev/grass_src cmbarton$ cd ./lib/external/shapelib
cmb-MBP-2:~/grass_dev/grass_src/lib/external/shapelib cmbarton$ make
make lib
cc -dynamiclib -compatibility_version 6.3 -current_version 6.3 -install_name
/Applications/Grass/GRASS-6.3.app/Contents/MacOS/lib/libgrass_shape.dylib -o
/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib/libgras
s_shape.6.3.svn.dylib
-L/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib
OBJ.i686-apple-darwin8.11.1/shpopen.o OBJ.i686-apple-darwin8.11.1/dbfopen.o
(cd /Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib; ln
-f -s libgrass_shape.6.3.svn.dylib
s_shape.dylib)
ld: Undefined symbols:
_SASetupDefaultHooks
/usr/bin/libtool: internal link edit command failed
make[1]: ***
[/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib/libgra
ss_shape.6.3.svn.dylib] Error 1
make: *** [default] Error 2
cmb-MBP-2:~/grass_dev/grass_src/lib/external/shapelib cmbarton$ cd
cmb-MBP-2:~/grass_dev/grass_src cmbarton$ cd ./db/drivers/dbf
cmb-MBP-2:~/grass_dev/grass_src/db/drivers/dbf cmbarton$ make
gcc -L/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib
-o
/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/driver/db/d
bf OBJ.i686-apple-darwin8.11.1/column.o OBJ.i686-apple-darwin8.11.1/cursor.o
OBJ.i686-apple-darwin8.11.1/db.o OBJ.i686-apple-darwin8.11.1/dbfexe.o
OBJ.i686-apple-darwin8.11.1/describe.o OBJ.i686-apple-darwin8.11.1/driver.o
OBJ.i686-apple-darwin8.11.1/error.o OBJ.i686-apple-darwin8.11.1/execute.o
OBJ.i686-apple-darwin8.11.1/fetch.o OBJ.i686-apple-darwin8.11.1/listtab.o
OBJ.i686-apple-darwin8.11.1/main.o OBJ.i686-apple-darwin8.11.1/select.o
OBJ.i686-apple-darwin8.11.1/str.o OBJ.i686-apple-darwin8.11.1/table.o
OBJ.i686-apple-darwin8.11.1/create_table.o -lgrass_dbmidriver
-lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbstubs
-lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis
-lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz
-lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_sqlp
-lgrass_shape -lgrass_dbstubs -lgrass_dbmibase -lgrass_gis -lgrass_datetime
-lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime
-lz -lgrass_datetime
-L/Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib -lgdal -lz
/usr/bin/ld: can't locate file for: -lgrass_shape
collect2: ld returned 1 exit status
make: ***
[/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/driver/db/
dbf] Error 1
============ configure string ==============
./configure --with-freetype
--with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/includ
e/freetype2 /Library/Frameworks/FreeType.framework/unix/include"
--with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
--with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config
--with-proj
--with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
--with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
--with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
--with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--without-postgres --without-mysql --with-odbc --with-sqlite
--with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
--with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
--with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
--with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-cxx
--with-tcltk-includes=/usr/local/tcltk/include
--with-tcltk-libs=/usr/local/tcltk/lib --with-x --without-motif
--without-glw --with-opengl=x11 --with-opengl-libs=/usr/X11R6/lib
--without-readline --prefix=/Applications/Grass --enable-macosx-app
--with-python
--with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.7.1/bin/wx-config
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080403/c9eb53b5/attachment-0001.html
