[GRASS-dev] Re: [GRASS GIS] #104: saving display to tiff or ppm
garbled when NVIZ is not top window
trac at osgeo.org
Fri Apr 4 19:34:49 EDT 2008
#104: saving display to tiff or ppm garbled when NVIZ is not top window
Reporter: dylan | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: fixed | Keywords: NVIZ openGL
Changes (by glynn):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:18 msieczka]:
> Replying to [comment:17 glynn]:
> > Can you try this one instead?
> > attachment:ticket:104:do_zoom-error.2.diff
> Allright! Same "X Error" crops out but no crash this time and the full-
res ppm output completes.
I'm marking this as resolved.
The original problem (with using the window for rendering when creating
PPM files) is essentially a "cantfix".
With the fixes to the code which uses GLX Pixmaps and pBuffers, you should
only need to use the window on systems where no other option is available
(and in that case, there is simply no solution; you just have to manually
ensure that nothing occludes the window during rendering).
Ticket URL: <http://trac.osgeo.org/grass/ticket/104#comment:19>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
