[GRASS-dev] Have Elevation raster maps always CELL data type
Hamish
hamish_b at yahoo.com
Fri Apr 4 22:36:47 EDT 2008
roberto caselli wrote:
> Is the unit of measurement in meters ?
elevation can be in whatever units you like. Typically they are in meters
but that is not required. You can use r.support to add meta-data info
about what units were used.
> PS: I got the spearfish data set.
the elevation maps supplied with the spearfish dataset are all in meters,
AFAIK.
GRASS> r.info elevation.dem
Data Description:
Elevation above mean sea level in meters for spearfish database
Hamish
____________________________________________________________________________________
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
http://tc.deals.yahoo.com/tc/blockbuster/text5.com
