[GRASS-dev] v.report broken when UNITSPARAM is quoted
Hamish hamish_b at yahoo.com
Fri Apr 4 23:02:18 EDT 2008
Maciej Sieczka wrote:
> In v.report r30407, lines 153 and 162, the UNITSPARAM variable became
> quoted. This makes the script print empty output when no explicit unit
> is specified, because v.to.db syntax becomes internaly eg.:
> v.to.db -p map=tmcz opt=coor col=dummy1,dummy2,dummy3 ''
> and the empty single quotes in the end of the string results in an
> error:
> Sorry <> is not a valid option
> Anybody minds if I strip the problematic double quotes off?
ah, sorry about that, fixed in r30864 and r30865 (went ahead and did it
myself as it was my fault & it had been backported with another fix).
thanks for spotting it.
Hamish
      ____________________________________________________________________________________
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
http://tc.deals.yahoo.com/tc/blockbuster/text5.com
