[GRASS-dev] Re: [GRASS GIS] #117: r.digit fails if launched from menu
GRASS GIS trac at osgeo.org
Sat Apr 5 20:45:52 EDT 2008
  Reporter:  4everskiff  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect      |      Status:  new
  Priority:  major       |   Milestone:  6.3.0
 Component:  default     |     Version:  6.3.0 RCs
Resolution:              |    Keywords:
Comment (by hamish):
 Hamish:
 > > r.digit works fine if launched from the WinGRASS command line?!
 Marco:
 > Yes, this is WinGRASS (Native Windows Binary) and r.digit works fine if
 started
 > from command line
 You can really digitize then view a map created with it? As far as I knew
 r.digit needed an interactive xmon window, which is only available if
 using X11. It should fail with a "no monitor found" error *after* you give
 it a map name.
 Perhaps something changed, but this surprises me.
 I have backported grass-xterm-wrapper to the 6.3.0 branch, but I hope
 others can add more xterm compatible terms to the list as needed.
 see also previous discussion:
   http://thread.gmane.org/gmane.comp.gis.grass.devel/14702
   http://thread.gmane.org/gmane.comp.gis.grass.devel/24109
 re r20925, I assume that the various distro's x-terminal-emulator wrappers
 have gotten their act together re gnome-terminal since last time we tried.
 It works for me on debian (points to /usr/bin/gnome-terminal.wrapper which
 translates command line options); could Ubuntu users please re-test to see
 if r.digit now works from the gis.m menu? (that's where the earlier
 problems were reported)
 I don't like changing this so late in the RC cycle, but hopefully it helps
 more than it harms.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:7>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
