[GRASS-dev] g.mlist, g.mremove fails in non-English locale
Maciej Sieczka tutey at o2.pl
Mon Apr 7 02:11:02 EDT 2008
Hamish pisze:
> Maciej Sieczka wrote:
>> What's wrong?
> The g.mlist script relies on the g.list module being run untranslated
Ah right.
> The immediate fix is to add a couple of lines to the start of the script
> temporarily disabling the locale settings, much like is done for scripts
> that use awk to stop "," being used as the decimal marker.
I think this is a good idea for all shell scripts then. Many use grep,
sed, tr etc. like if the output was always in English.
> The long term fix is to rewrite g.mlist not to be a hack.
I'm affraid the issue is not limited to g.mlist.
Maciek
