[GRASS-dev] what if: a new GRASS directory layout?
Glynn Clements
glynn at gclements.plus.com
Mon Apr 7 14:29:50 EDT 2008
Ivan Shmakov wrote:
> > To make concurrent access work, updating a map would need to be an
> > atomic operation, so that any module which reads the map sees either
> > the "before" version or the "after" version, and never sees an
> > "in-progress" version.
> And that's simple. It's only the current layout of the GRASS
> database directory that makes it hard. The new layout may be
> like the following:
[snip]
A simpler (and less radical) solution is to simply all elements of a
map in a common directory. Then, you replace the directory as a whole
rather than individual files. ISTR that this is already planned for
the future.
The downside is that you can't atomically replace a directory in the
same way that you can a file. You have to rename the destination
first, which leaves a small window when the map doesn't exist. But a
transient state with no map is still better than the current situation
of a transient state with an inconsistent map.
Full transaction support would be nice, but I don't know if it's worth
the substantial effort involved in implementing it.
In any case, all of these mechanisms would require substantial changes
to a large number of modules. And there's still the issue of vector
maps, which are often updated in-place.
