[GRASS-dev] r.out.gmap: export raster to Google Map tiles
Hamish
hamish_b at yahoo.com
Tue Apr 8 05:23:05 EDT 2008
Tomas Cebecauer wrote:
> Note that modul has to be run from LOCATION with correct mercator
> projection used by google maps (epsg 900913).
note that GRASS does not currently include /usr/share/proj/esri.extra
(and other unofficial "add-on" EPSG codes in that dir) in
$GISBASE/etc/ogr_csv/*, so you can't use 'g.proj -c epsg=900913' to
create the location.
but you can look in the esri.extra file to get the needed
'g.proj -c proj4=' parameters.
Hamish
____________________________________________________________________________________
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
http://tc.deals.yahoo.com/tc/blockbuster/text5.com
