[GRASS-dev] g.mapsets revision 30712
Markus Neteler
neteler at osgeo.org
Tue Apr 8 16:52:26 EDT 2008
On Sat, Apr 5, 2008 at 1:16 AM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Martin Landa wrote:
> > 2008/4/4, Markus Neteler OSGeo <neteler at osgeo.org>:
> > > > r30712 | martinl | 2008-03-24 11:19:11 +0000 (Mon, 24 Mar 2008) | 2 lines
> > > > g.mapsets: (cosmetics) message cleaning, some minor changes in manual,
> > > > tcl/tk-related code removed
> > Glynn:
> > > > Presumably g.mapsets.tcl should be removed, now that it is no longer
> > > > used.
> > > The CMD line version of g.mapsets is lacking a parameter to
> > > remove (multiple) mapsets from the search path.
> > > This should be added before removing the Tcl version.
> > > I tried but got lost in the tokenizer.
> > try the attached patch (for review), Martin
> I should probably have read this message before going ahead and making
> my own patch as soon as I read Markus' message.
Thanks for your quick replies!
Please submit the final version for testing to SVN...
Markus
