[GRASS-dev] Re: [GRASS-user] trouble with v.rast.stats under WINGRASS
Moritz Lennert mlennert at club.worldonline.be
Tue Apr 8 17:08:25 EDT 2008
On 08/04/08 23:03, Moritz Lennert wrote:
> On 08/04/08 18:04, Niels Thevs wrote:
>> Dear GRASS users,
>> I am using WINGRASS 6.3 (RC5) and tried the command v.rast.stats. But
>> I encountered the error messages below, though the vector and raster
>> are in the same mapset.
>> split1 at PERMANENT_3280.0 is not in the current mapset (PERMANENT)
>> An error occurred while converting vector to raster
>> G__open(r): mapset (PERMANENT) doesn't match xmapset (PERMANENT_3280.0)
>> Does anybody know, how to overcome this problem ?
> This was fixed by Hamish here http://trac.osgeo.org/grass/changeset/30136
> but apparently it did not get backported.
Sorry, I correct myself: it was backported to RC6, so just install that
version and you should be fine.
Moritz
