[GRASS-dev] Re: what if: a new GRASS directory layout?
Glynn Clements
glynn at gclements.plus.com
Wed Apr 9 12:24:13 EDT 2008
Ivan Shmakov wrote:
> > In-process references could be maintained by making a copy (or hard
> > link) to the inventory, so that the GC treats it as "live". You would
> > need some kind of clean-up mechanism to handle any copies which are
> > left behind if a module crashes.
> However, having GC to process all the inventories won't be
> efficient (unless these are stored in a database's table with
> appropriate indices.) So, I had in mind keeping a references
> file along with each object file.
Ah; if you're talking about back-references, one thing to bear in mind
is permissions: you can use maps from mapsets for which you only have
read permission, and not write permission.
[This issue has already arisen with respect to reclass maps and the
reclassed_to file. That was the first GRASS bug I ever fixed.]
That also means that garbage collection would need to scan the entire
location, not just individual mapsets. Actually, re-projection can
span locations, so you would potentially need to scan the entire
database.
> > [BTW, it has been pointed out that this can reduce the maximum number
> > of maps per mapset, as the limit on an inode's hard link count limits
> > the maximum number of subdirectories, while there is usually no fixed
> > limit on the number of files. E.g. on Linux' ext2fs, the maximum hard
> > link count is 65535, so you can't have more than 65533 subdirectories.]
> While the inventory scheme is free from hitting this limit.
OTOH, if you don't use subdirectories, you will have many more files
in a single directory. This can be a major performance issue on some
filesystems.
