[GRASS-dev] Updated OGR/SHAPELIB based DBF driver crashing with
GRASS SVN
Frank Warmerdam
warmerdam at pobox.com
Wed Apr 9 13:01:44 EDT 2008
Glynn Clements wrote:
> Markus Neteler wrote:
>> after syncing (as regularly) the DBF driver from SHAPELIB embedded
>> in OGR, we face the problem that it no longer works with older GDAL
>> versions than current SVN:
>> http://trac.osgeo.org/grass/ticket/110
>> I don't know what to do. In essence, I don't want to fork our version
>> from yours.
>> Any ideas?
> I suggest using a "stub" implementation of the I/O hooks. E.g.:
> typedef struct {
> FILE* (*FOpen) ( const char *filename, const char *path);
> size_t (*FRead) ( void *p, size_t size, size_t nmemb, FILE* file);
> size_t (*FWrite)( void *p, size_t size, size_t nmemb, FILE* file);
> long (*FSeek) ( FILE* file, long offset, int whence );
> long (*FTell) ( FILE* file );
> int (*FFlush)( FILE* file );
> int (*FClose)( FILE* file );
> void (*Error) ( const char *message );
> } SAHooks;
> static void error_fn( const char *message )
> G_fatal_error("%s", message);
> static void SASetupDefaultHooks( SAHooks *psHooks )
> psHooks->FOpen = fopen;
> psHooks->FRead = fread;
> psHooks->FWrite = fwrite;
> psHooks->FSeek = fseek;
> psHooks->FTell = ftell;
> psHooks->FFlush = fflush;
> psHooks->FClose = fclose;
> psHooks->Error = error_fn;
Folks,
I'm just trying to catch up on this topic. There is already a stdio
based implementation in shapelib itself. I have attached it,and it is
normally in a file called safileio.c.
I'm afraid I'm uncertain of the implications of mixing the Shapelib 1.3
code with GDAL's using Shapelib 1.2. It seems potentially like it could
be a problem.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
Type: text/x-csrc
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080409/f91cd506/safileio-0001.bin
