[GRASS-dev] Re: [GRASS GIS] #114: wxPython GUI fails in Vista
trac at osgeo.org
Wed Apr 9 21:52:43 EDT 2008
Reporter: jrobins | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: minor | Milestone: 6.3.0
Component: Python | Version: 6.3.0 RCs
Resolution: worksforme | Keywords: wxPython, Windows, Vista
Changes (by jrobins):
* priority: major => minor
* status: new => closed
* resolution: => worksforme
Comment:
I apologize for reporting this trivial error. I found that the root of
this problem was that my [[BR]]
GIS data directory had been set to 'c:\grass\GIS Database'. This is the
default value[[BR]]
when winGRASS is installed using the experimental installer program. The
space in the[[BR]]
directory name was causing problems inside the Python code. When I
changed the GISDBASE[[BR]]
variable to a path without spaces, the wxPython GUI launched correctly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/114#comment:1>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
