[GRASS-dev] Re: g.region enhacements
Ivan Shmakov
ivan at theory.asu.ru
Thu Apr 10 04:09:00 EDT 2008
>>>>> Ivan Shmakov <ivan at theory.asu.ru> writes:
>>>>> Maciej Sieczka <tutey at o2.pl> writes:
>>> Talking about g.region vect= - I'd find it very usefull if it
>>> honored the 3d vector coordinates too. Currently one has to set top
>>> and bottom manually in accordance with his 3d vector.
>> Do you mean something like the following?
> BTW, I'm not familiar with either 3D-vectors or 3D-rasters, so could
> someone with a better knowledge of them test this (and possibly the
> other [1]) patch? Or should I put it to Trac?
> [1] http://permalink.gmane.org/gmane.comp.gis.grass.devel/26185
I have opened a ticket [1] for the issue.
[1] http://trac.osgeo.org/grass/ticket/121
