[GRASS-dev] Re: [GRASS GIS] #110: db/drivers/dbf fail to build due
to undefined reference to 'SASetupDefaultHooks' (SHAPELIB)
trac at osgeo.org
Fri Apr 11 07:00:39 EDT 2008
#110: db/drivers/dbf fail to build due to undefined reference to
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: dbf
Comment (by martinl):
Replying to [comment:9 neteler]:
> If I now remove the GDAL dependency from db/driver/dbf/Makefile it does
not compile. If I keep it, it compiles. Problem solved?
well, it is possible now to compile shapelib and dbf driver. Copying
vector map using dbf driver fails
GRASS 6.3.svn (spearfish60):~/smetiste/grass_trunk > g.copy vect=soils,s
Copy vector <soils at PERMANENT> to current mapset as <s>
dbmi: Protocol error
WARNING: Cannot open select cursor: 'select * from soils where 0 = 1'
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:11>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
