[GRASS-dev] Re: [GRASS-user] Problem removing mapsets in g.mapset
Martin Landa
landa.martin at gmail.com
Fri Apr 11 10:52:34 EDT 2008
should be fixed now
http://trac.osgeo.org/grass/changeset/30939
Martin
2008/4/11, Patton, Eric <epatton at nrcan.gc.ca>:
> I can't seem to remove mapsets in g.mapsets using the new removemapset parameter. Ex:
> $ g.mapsets -p
> ED_Legacy_Data PERMANENT 2007006
> $ g.mapsets rem=2007006
> $ g.mapsets -p
> g.list is still fetching raster map names from the removed mapset as well:
> $ g.list rast
> raster files available in mapset <ED_Legacy_Data>:
> <snip>
> raster files available in mapset <PERMANENT>:
> <snip>
> raster files available in mapset <2007006>:
> (all rasters follow)
> ~ Eric.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
