[GRASS-dev] Re: [GRASS GIS] #50: g.copy segfaults (debian.gfoss.it
package) [and latest SVN]
trac at osgeo.org
Sat Apr 12 00:15:21 EDT 2008
#50: g.copy segfaults (debian.gfoss.it package) [and latest SVN]
Reporter: steko | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.3.0 RCs
Resolution: | Keywords: g.copy
Comment (by dylan):
Replying to [comment:6 glynn]:
> Replying to [comment:5 dylan]:
> > I have attached two strace logs, one from the working version of
g.copy (-O0), and one from the non-working version (-O1).
> strace doesn't provide enough detail for this kind of problem. All that
can be deduced from the backtraces is that the segfault occurs sometime
after the "cell" files are closed (recursive_copy(),
general/manage/lib/do_copy.c:152) but before the access() test for whether
the cellhd file exists (G__make_mapset_element(), lib/gis/mapset_msc.c:60,
called from do_copy(), general/manage/lib/do_copy.c:42).
> AFAICT, the segfault could be occurring in recursive_copy(),
G_verbose(), G__make_mapset_element() or do_copy().
> A gdb C backtrace would be more useful, even if it isn't enough to
pinpoint the problem. A C backtrace will still report the correct
function; it just won't necessarily report the correct line number, or the
actual state of any variables (it *might* get this information right, but
as you can't tell whether the information is accurate, it doesn't
necessarily help).
Thanks for the tips Glynn. Any further hints on how to do the above?
> Also, it would be useful to know whether the problem occurs when lib/gis
is compiled with optimisation or when general/manage is compiled with
optimisation.
After the configure step, how can I disable optimization for specific
parts of the source tree?
Ticket URL: <http://trac.osgeo.org/grass/ticket/50#comment:7>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
