[GRASS-dev] Re: [GRASS GIS] #50: g.copy segfaults (debian.gfoss.it package) [and latest SVN]
GRASS GIS trac at osgeo.org
Sat Apr 12 10:29:02 EDT 2008
  Reporter:  steko    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  6.3.0 RCs
Resolution:           |    Keywords:  g.copy
Comment (by hamish):
 fyi, debugging howto hints can be viewed/added here:
   http://grass.gdf-hannover.de/wiki/GRASS_Debugging
 If GDB is not an option I have found that just adding really basic printfs
 can help to split the problem in half, then in half again, and so on until
 you isolate the line the problem is on.
   printf("--> made it this far.  fn():line xxxx\n");
 the raster libs could use a few new permanent G_debug()s at key spots.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/50#comment:9>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
