[GRASS-dev] Re: [GRASS GIS] #50: g.copy segfaults
(debian.gfoss.it package) [and latest SVN]
Dylan Beaudette
dylan.beaudette at gmail.com
Sat Apr 12 17:06:12 EDT 2008
On Sat, Apr 12, 2008 at 1:15 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> GRASS GIS wrote:
> > #50: g.copy segfaults (debian.gfoss.it package) [and latest SVN]
> > Reporter: steko | Owner: grass-dev at lists.osgeo.org
> > Type: defect | Status: new
> > Priority: major | Milestone: 6.4.0
> > Component: default | Version: 6.3.0 RCs
> > Resolution: | Keywords: g.copy
> > Comment (by dylan):
> > Replying to [comment:6 glynn]:
> > > Replying to [comment:5 dylan]:
> > > > I have attached two strace logs, one from the working version of
> > g.copy (-O0), and one from the non-working version (-O1).
> > > strace doesn't provide enough detail for this kind of problem. All that
> > can be deduced from the backtraces is that the segfault occurs sometime
> > after the "cell" files are closed (recursive_copy(),
> > general/manage/lib/do_copy.c:152) but before the access() test for whether
> > the cellhd file exists (G__make_mapset_element(), lib/gis/mapset_msc.c:60,
> > called from do_copy(), general/manage/lib/do_copy.c:42).
> > > AFAICT, the segfault could be occurring in recursive_copy(),
> > G_verbose(), G__make_mapset_element() or do_copy().
> > > A gdb C backtrace would be more useful, even if it isn't enough to
> > pinpoint the problem. A C backtrace will still report the correct
> > function; it just won't necessarily report the correct line number, or the
> > actual state of any variables (it *might* get this information right, but
> > as you can't tell whether the information is accurate, it doesn't
> > necessarily help).
> > Thanks for the tips Glynn. Any further hints on how to do the above?
> $ gdb g.copy
> > run rast=t1,t1_copy --o
> When it stops due to the segfault:
> > where
> > quit
> > > Also, it would be useful to know whether the problem occurs when lib/gis
> > is compiled with optimisation or when general/manage is compiled with
> > optimisation.
> > After the configure step, how can I disable optimization for specific
> > parts of the source tree?
> First, compile everything. Then, re-compile specific parts with
> different flags using e.g.:
> make -C lib/gis clean
> make -C lib/gis CFLAGS1='-g -O0'
> Glynn Clements <glynn at gclements.plus.com>
Thanks for the tips Gylnn.
Some tests:
1. everything _but_ lib/gis compiled with "-O2"
(segmentation fault)
2. make everything _but_ lib/gis and general/manage with "-O2":
make -C general/manage/ clean
make -C general/manage/ CFLAGS1='-g -O0'
(NO segfault)
3. make everything _but_ general/manage with "-O2":
make -C lib/gis CFLAGS1='-g -O2'
(NO segfault)
4. enable optimization on general/manage: (everything else compiled with -O2)
make -C general/manage clean
make -C general/manage CFLAGS1='-g -O2'
(segfault)
5. test with -O1:
make -C general/manage CFLAGS1='-g -O1'
(segfault)
... so it looks like something in general/manage is screwed up by
optimization. Incrementally adding optimization:
make -C general/manage/cmd/ clean
make -C general/manage/cmd/ CFLAGS1='-g -O0'
(segfault)
# test separately:
make -C general/manage/cmd/ CFLAGS1='-g -O2'
make -C general/manage/lib/ clean
make -C general/manage/lib/ CFLAGS1='-g -O0'
(segfault)
# reset
make -C general/manage CFLAGS1='-g -O0'
(NO segfault)
Final thoughts: something in 'general/manage' . I can't really
speculate any further.
