[GRASS-dev] Fixing progress bar crash in TclTk gui
Michael Barton
michael.barton at asu.edu
Sat Apr 12 21:30:41 EDT 2008
On 3/30/08 2:17 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
>> There is one place that is a serious problem where we could really
>> use a much more experienced TclTk programmer like you to sort out:
>> the progress bar. It seems like it ought to be straightforward, but
>> there is something wrong with the progress bar code so that if a
>> module executes too quickly, it crashes the entire TclTk interface.
> AFAICT, the issue is due to an event handler being re-entered through
> the "update" command.
> I note that ProgressBar::_modify calls update. One option is to remove
> that call. Any other options (i.e. allowing event handlers to be
> re-entered) are quite complex.
Now that I can compile again, I went to look for this to see if your
suggested remedy works. I can't find where you are talking about. Is this in
the GRASS code or in the TclTk code?
Michael
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
