[GRASS-dev] Re: [GRASS GIS] #124: d.legend: apply arbitrary labels to a smooth floating-point colorbar
GRASS GIS trac at osgeo.org
Mon Apr 14 17:38:05 EDT 2008
  Reporter:  epatton      |       Owner:  hamish
      Type:  enhancement  |      Status:  assigned
  Priority:  minor        |   Milestone:  6.4.0
 Component:  default      |     Version:  svn-trunk
Resolution:               |    Keywords:  colorbar, d.legend
Changes (by hamish):
  * status:  new => assigned
  * owner:  grass-dev at lists.osgeo.org => hamish
 * cc: grass-dev at lists.osgeo.org (added)
Comment:
 A few other buggy things to note,
 use=0.0,0.2,0.4,0.6,0.8,1.0 only keeps the int part.
 IIRC use= for FP with a categorty label used to display the label but
 doesn't anymore (may be bad memory, need to go back and test with GRASS 5)
 Eric, may I ask for an example? Lock a tick-label at 0? Log scale?
 Should we allow numbers to overlap?
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/124#comment:1>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
