[GRASS-dev] Re: [GRASS GIS] #111: r.los error "r.los.exe there are encountered to problem and needs to close"
GRASS GIS trac at osgeo.org
Wed Apr 16 06:54:08 EDT 2008
  Reporter:  gsancho  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  unspecified
Resolution:           |    Keywords:  wingrass r.los
Changes (by 4everskiff):
 * cc: marco.pasetti at alice.it (added)
Comment:
 Replying to [ticket:111 gsancho]:
 > Hello.
 > I have a problem with the operation r.los in winGrass(native). I have
 been testing different maps and when a distance is greater than 80-100
 pixels (map pixels) a system error is thrown.
 > To put an example, in spearfish data base and the elevation.dem map,
 grass fails from 2524m on up  (with the height of the observer set to 1m)
 > The command would be:
 > r.los input=elevation.dem output=los coordinate=599505,4921010
 max_dis=2525
 > The error that is reported is a system error: "r.los.exe there are
 > Thanks and regards.
 I checked the command on WinGRASS-6.3.0RC6 (WinXP). It's the same for me.
 BTW, the error seems to be not related to WinGRASS, but to the map in use
 or to the module as cross-platform error (maybe related to the dimension
 of data to be processed?). For example, I launched the command on another
 raster dem map (with a resolution of 20m) with dist set to 3000, and it
 works fine, while it fails with 3001!
 Could someone test it also on linux or mac?
 Thank you
 Marco
Ticket URL: <http://trac.osgeo.org/grass/ticket/111#comment:1>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
