[GRASS-dev] Re: [GRASS GIS] #127: WinGRASS Tcl/Tk GUI - Text
formatting error in Output window
trac at osgeo.org
Wed Apr 16 14:25:12 EDT 2008
#127: WinGRASS Tcl/Tk GUI - Text formatting error in Output window
Reporter: 4everskiff | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.3.0
Component: Tcl | Version: 6.3.0 RCs
Resolution: | Keywords: Text output, winGRASS
Comment (by 4everskiff):
Replying to [comment:1 pkelly]:
> Does this really apply to every command? Can you give another example
other than "g.region -p"?
> Also, how was the location created? Does the same behaviour occur in a
location that wasn't created using WinGRASS (e.g. does it happen with
spearfish?)
> Potential technical explanation:
> I suspect it might just be another example of G_getl() needing to be
replaced by G_getl2() when reading the projections file and creating the
PROJ_INFO - the newline character is stripped off but the carriage return
isn't.
> IMHO the best solution to this is to audit all occurences of G_getl()
and replace them with G_getl2() if there are no potential problems, then
replace G_getl() itself with a wrapper to G_getl2().
Hi Paul,
I confirm that I dedected the same bug with other commands (such as
r.horizon, for example) and also with spearfish.
Marco
Ticket URL: <http://trac.osgeo.org/grass/ticket/127#comment:2>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
