R: R: [GRASS-dev] GRASS 6.3.0 to be released
Glynn Clements
glynn at gclements.plus.com
Wed Apr 16 20:37:39 EDT 2008
Moritz Lennert wrote:
> > >I would suggest two installers: one for GRASS alone, and one for the
> > various dependencies (PROJ, GDAL, MSys, ...). The idea is that you
> > shouldn't have to download all of the dependencies each time a new
> > version of GRASS is released.
> > we could do as follows:
> > 1. a *complete*, *first time* GRASS installer, based on latest release,
> > with all the dependencies built-in
> > 2. and *updater*, installed along the *first installation*, that check
> > the WinGRASS repository looking for last GRASS updates, and
> > download/install only the latest updated files (both for GRASS and
> > dependencies). It would be not an easy work, but I think that I'll can
> > do it... even if not very soon :-)
> This actually sounds much more sophisticated than what Glynn proposed.
> Could you not simply propose one installer with only the latest
> (complete) GRASS binaries. This installer could check for any existing
> installation of GRASS and propose to erase that before installing the
> new version, or install the new version next to the old.
> The question then is: do we need a "complete" installer with everything
> in it (as you suggest), or can we impose the burden of two installers on
> people, i.e. as Glynn suggests: one GRASS installer + one Dependencies
> installer. I think this would be the best solution for us, but it would
> mean that at least for the first installation, users will have to
> install two packages. If the GRASS installer could test for the
> installation of the other package and propose to download it and lauch
> its installation autmagically, then this might be the best solution.
I don't think that you even need to go that far. If downloading and
running (in the correct order) two installers is beyond the user's
abilities, chances are that they'll spend a couple of days flooding
the grass-user ML with noob questions before giving up on GRASS
altogether.
