[GRASS-dev] Re: [GRASS GIS] #128: NVIZ fails to load vector points
without other map
trac at osgeo.org
Thu Apr 17 04:05:08 EDT 2008
#128: NVIZ fails to load vector points without other map
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: nviz
Comment (by neteler):
I get:
nviz point=lidar1map3d
Vector file lidar1map3d loaded with 38008 points.
curr = 1.0
curr = 1.0
curr = nan
Error in startup script: can't use non-numeric floating-point value as
operand of "*"
while executing
"expr int($curr * 1)"
(procedure "Nv_mkFloatScale" line 17)
Ticket URL: <http://trac.osgeo.org/grass/ticket/128#comment:6>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
