[GRASS-dev] Re: [GRASS GIS] #124: d.legend: apply arbitrary labels to a smooth floating-point colorbar
GRASS GIS trac at osgeo.org
Thu Apr 17 04:07:22 EDT 2008
  Reporter:  epatton      |       Owner:  hamish
      Type:  enhancement  |      Status:  assigned
  Priority:  minor        |   Milestone:  6.4.0
 Component:  default      |     Version:  svn-trunk
Resolution:               |    Keywords:  colorbar, d.legend
Comment (by hamish):
 Using the range= and labelnum= options you should be able to get the look
 you are after.
 d.legend range=0,-200
 then you get labelnum=5 ticks at: 0,-50,-100,-150,-200
  * adjust your color rules so that they cover the full range
  * with the range= option do max,min instead of min,max to flip the legend
 vertically (or use the -f flag)
 see also ps.map's colorbar legends. They work the other way and try to
 fall on round numbers automatically. Both ways have their merits, but I
 guess I hear less complaints about the ps.map way. (but less people use
 that, so who knows)
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/124#comment:3>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
