[GRASS-dev] Re: [GRASS GIS] #128: NVIZ fails to load vector points
without other map
trac at osgeo.org
Fri Apr 18 20:19:11 EDT 2008
#128: NVIZ fails to load vector points without other map
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: nviz
Comment (by hamish):
g.region -d
nviz points=archsites
# change z-exag from -0.0 to 1.0
divide by zero
while executing
"expr $val/floor($val/$res)"
(procedure "Nv_floatscaleCallback" line 49)
AFAICT this is because the value $res is set from is used uninitiated.
"$res" there is -0.0, set a few lines above with:
set res [lindex [$S.scale configure -resolution] 4]
if there is a raster (or vol?) surface given from the command line it
calcs $res ok. If not it doesn't. Even if you add in a new raster surface
after starting with "nviz points=" it doesn't set $res and then gets
quickly stuck in some infinite loop.
So how does $res get set for raster maps? If there is no raster map can a
starting value be derived from the current region settings?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/128#comment:10>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
