[GRASS-dev] [GRASS GIS] #132: Extend GRASS-command history (at
least to 1000) by default
Glynn Clements
glynn at gclements.plus.com
Sat Apr 19 00:28:53 EDT 2008
GRASS GIS wrote:
> #132: Extend GRASS-command history (at least to 1000) by default
> Reporter: nikos | Owner: grass-dev at lists.osgeo.org
> Type: enhancement | Status: new
> Priority: major | Milestone: 6.4.0
> Component: default | Version: unspecified
> Keywords: |
> Why not extend the command-history by default?
Are you talking about the shell's command history or a map's history?
For the latter, one problem is that the History structure uses
fixed-sized fields:
#define MAXEDLINES 50
#define RECORD_LEN 80
struct History
char mapid[RECORD_LEN];
char title[RECORD_LEN];
char mapset[RECORD_LEN];
char creator[RECORD_LEN];
char maptype[RECORD_LEN];
char datsrc_1[RECORD_LEN];
char datsrc_2[RECORD_LEN];
char keywrd[RECORD_LEN];
int edlinecnt;
char edhist[MAXEDLINES][RECORD_LEN];
Increasing MAXLINES to 1000 could be a significant waste of memory for
modules which have a lot of maps open.
The I/O code only writes as many characters per line and as many lines
as are actually used, so disk space isn't a factor:
fprintf (fd, "%s\n", hist->mapid) ;
fprintf (fd, "%s\n", hist->title) ;
fprintf (fd, "%s\n", hist->mapset) ;
fprintf (fd, "%s\n", hist->creator) ;
fprintf (fd, "%s\n", hist->maptype) ;
fprintf (fd, "%s\n", hist->datsrc_1) ;
fprintf (fd, "%s\n", hist->datsrc_2) ;
fprintf (fd, "%s\n", hist->keywrd) ;
for(i=0; i < hist->edlinecnt; i++)
fprintf (fd, "%s\n", hist->edhist[i]) ;
It probably wouldn't be particularly hard to replace all of the arrays
with pointers, i.e.:
struct History
char *mapid;
char *title;
char *mapset;
char *creator;
char *maptype;
char *datsrc_1;
char *datsrc_2;
char *keywrd;
int edlinecnt;
char **edhist;
The main issue is that any modules which fill in the history fields
themselves (rather than simply calling e.g. G_short_history()) would
need to use e.g.:
hist.datasrc_1 = G_store(src);
instead of:
strcpy(hist.datasrc_1, src);
Tracking down all such cases might take a while.
