[GRASS-dev] GRASS6.3 on Airbook and GRASS SVN on RH
Glynn Clements
glynn at gclements.plus.com
Mon Apr 21 03:45:22 EDT 2008
Helena Mitasova wrote:
> >> but I am having troubles compiling the SVN GRASS with wxPython -
> >> although the configure finds wxprec.h it does not find pseudodc.h,
> >> in spite of the fact that I have it (maybe in a wrong place?)
> >> (see more below).
> >> Thanks a lot for any advice,
> >> Helena
> >> this is what I tried to add to the config file
> >> --with-python \
> >> --with-wxwidgets=`which wx-config` \
> >> --with-wxwidgets-includes=/usr/lib/wxPython-2.8.7.1-gtk2-unicode/
> >> include/wx-2.8/
> >> but I still get the same error:
> >> checking whether to use wxWidgets... yes
> >> checking for wx-config... /usr/bin/wx-config
> >> checking wxWidgets version... 2.8.4
> >> checking for wx/wxprec.h... yes
> >> checking for wx/wxPython/pseudodc.h... no
> >> configure: error: *** Unable to locate wxWidgets includes.
> >> (I tried also
> >> include/wx-2.8/wx/wxPython)
> >> This is where the related files are located:
> >> deliboz% locate pseudodc.h (this gives error)
> >> /usr/lib/wxPython-2.8.7.1-gtk2-unicode/include/wx-2.8/wx/wxPython/
> >> pseudodc.h
> > Try:
> > include/wx-2.8
> I did, but it still cannot find it,
Oops; there isn't a --with-wxwidgets-includes= switch (configure
silently ignores unknown switches). The compilation and linking
switches are determined solely by the output from wx-config.
If the wxPython-specific headers don't get put into the wx include
directory, you lose. You could try making a symlink.
