[GRASS-dev] GRASS6.3 on Airbook and GRASS SVN on RH
Glynn Clements
glynn at gclements.plus.com
Mon Apr 21 06:58:57 EDT 2008
Martin Landa wrote:
> A symlink should work, anyway do we need to add --wx-widgets-includes
> and wx-widgets-libs to the configuration script?
If we stop using internal wxPython functions in C++ code, the problem
should go away. As for workarounds ... really, I'd rather just see the
actual problem fixed.
> Do you have wxPython-specific wx-config somewhere? E.g. in Mandriva
> there is /usr/lib/wxPython/bin/wx-config.
What is it doing there? wx-config is part of wxWidgets; it has nothing
to do with Python.
