[GRASS-dev] patch for v.voronoi/v.delaunay
Markus Neteler
neteler at osgeo.org
Tue Apr 22 19:07:01 EDT 2008
Hi Benjamin,
On Fri, Feb 1, 2008 at 2:16 PM, Benjamin Ducke
<benjamin.ducke at ufg.uni-kiel.de> wrote:
> Hi all,
> As per request, I have patched v.delaunay (source in v.voronoi/)
> very carefully.
> The memory handling now seems to work better. At least I was able
> to triangulate a map with ca 30000 points. Anything more and my
> system starts thrashing badly (1 GB, with a lot of other apps running).
> Feel free to test with bigger inputs.
I tried with nearly 40k points and it worked.
> The output vector map will now also preserve the 3D coordinates of
> the original input points. However, the centroids for the triangles
> are all wrong (placed at z=0.0). I don't see a quick way of fixing
> this right now.
I have fixed it using Vect_tin_get_z() for delaunay (someone needs to
do it for voronoi).
I have submitted the fixed code to SVN:
http://trac.osgeo.org/grass/changeset/31079
For me it now generates a 3D Delaunay TIN.
> In fact, I'd prefer not to touch the current code for v.delaunay
> anymore. It is in urgent need of a complete overhaul as it is
> inefficient, hard to read and still full of site lib artefacts.
> Better to re-write from scratch with more time on my (or someone
> else's) hands.
Forthcoming...:
http://code.google.com/soc/2008/osgeo/appinfo.html?csaid=7599B5B1E8D1F20F
Markus
