[GRASS-dev] 6.3.0 is out! please prepare binaries...
Glynn Clements
glynn at gclements.plus.com
Wed Apr 23 02:24:38 EDT 2008
> > > Ok. So we don't care about the missing scripts (windows
> > > native only problem) and go ahead?
> > No, I think that you should back-port the scripts.
> Is this sufficient?
> http://trac.osgeo.org/grass/changeset/31071
You should also disable the construction of the symlinks.
This was the change in question:
http://trac.osgeo.org/grass/changeset/30749
It should be back-ported to 6.3 as a whole, i.e.:
svn merge -c 30749 https://svn.osgeo.org/grass/grass/trunk
