R: [GRASS-dev] 6.3.0 is out! please prepare binaries...
marco.pasetti at alice.it
Wed Apr 23 12:04:10 EDT 2008
Hi Markus,
>Hamish was so kind to do the backport.
>At this point we are ready to release.
I'm afraid to make so much *pressure*, but, since the 6.3.0 tarball was released, I promised qgis guys that I would have delayed the qgis release to put GRASS-6.3.0 in it... I would like very much to keep my promise... ;-)
If not ready with the tarball, can I build using releasebranch_6_3?
Thanks
Marco
Da: grass-dev-bounces at lists.osgeo.org per conto di Markus Neteler
Inviato: mer 23/04/2008 14.06
A: GRASS developers list
Oggetto: Re: [GRASS-dev] 6.3.0 is out! please prepare binaries...
On Wed, Apr 23, 2008 at 8:24 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> > Is this sufficient?
> > http://trac.osgeo.org/grass/changeset/31071
> You should also disable the construction of the symlinks.
> This was the change in question:
> http://trac.osgeo.org/grass/changeset/30749
> It should be back-ported to 6.3 as a whole, i.e.:
> svn merge -c 30749 https://svn.osgeo.org/grass/grass/trunk
Markus
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080423/7083e94e/attachment.html
