R: [GRASS-dev] Re: R: Linking gdal 1.5.1 in mingw
Joel Pitt
joel.pitt at gmail.com
Wed Apr 23 19:18:23 EDT 2008
On Wed, Apr 23, 2008 at 12:40 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> On Tue, 22 Apr 2008, marco.pasetti at alice.it wrote:
> > since I compiled it just yesterday, I don't see how could that be, if he
> followed my guide in every instruction. Libtool fails because he needs to
> work with different paths as set by default in the makefile; that's why it's
> necessaty to modify it.
> OK, I accept that you could edit the GNUMakefile instead of ltmain.sh,
> really it is the same problem that since 1.5, GDAL and MSYS are not friends.
Thanks for the help guys!
I had actually made a mistake with not editing the GNUMakefile... but
I went back and changed it, did a make clean, reconfigured and started
from scratch but obviously that wasn't sufficient...
Cheers,
J
