[GRASS-dev] PNG driver - Export
Alex Schulze schulzibabe at web.de
Thu Apr 24 08:10:41 EDT 2008
I want to export an image with the PNG driver, but there seems to be a problem. Always I get a vertical line with 1 Pixel width.
I use the following configuration for the export:
export GRASS_WIDTH=317
export GRASS_HEIGHT=317
export GRASS_PNGFILE=$GISDBASE/tester.png
export GRASS_TRANSPARENT=TRUE
export GRASS_TRUECOLOR=TRUE
d.mon start=PNG
d.rast map=tester
d.mon stop=PNG
r.info for this raster shows col=317 and row=317
When I use r.out.pgn everything is fine. I get an image (317x317) without this vertical line. But I need the transparence.
I use grass 6.2.2 under Ubuntu.
Is an error of myself or a bug?
best regards
Alex
_______________________________________________________________________
EINE FÜR ALLE: die kostenlose WEB.DE-Plattform für Freunde und Deine
Homepage mit eigenem Namen. Jetzt starten! http://unddu.de/?kid=kid@mf2
