[GRASS-dev] Re: [GRASS GIS] #93: db.table -p does not list all
tables -> deeper problems in PostgreSQL driver
trac at osgeo.org
Sun Apr 27 16:25:23 EDT 2008
#93: db.table -p does not list all tables -> deeper problems in PostgreSQL
driver
Reporter: harrikoo | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: PostgreSQL database db.table v.db.connect
Comment (by neteler):
Replying to [ticket:93 harrikoo]:
> This leads to another problem: it is not possible to create a new
database link for a vector to a table that is not visible in `db.table
-p`, althought the table does exist in the database. I did try this many
times, so I'm quite certain it's not a typo.
I assume that the mechanism used here is the same. If db.table doesn't see
it, also the rest won't see it.
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/93#comment:3>
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies. GRASS is official project of the Open Source Geospatial Foundation.
